Trap Speed - Rear Ends
Old Jul 6, 2005 | 07:42 PM
TrouserSnake's Avatar
Ok.. Here's my Question I have a modded 99 Z28 Convert M6
Im Trapping 115.. And I have the Stock rear end 3.42 Im comming Through the Traps right off the Rev Limiter in third Gear
If I go with a 4.10 Will my Trap Speed Decrese? I heard 4rth is the 1 to 1 ratio so Id wanna be in that comming through the Traps correct?
So Will my Trap Mph Incress with 4.10 or Drop off?
Old Jul 6, 2005 | 09:12 PM
rskrause's Avatar
Moderator
Re: Trap Speed - Rear Ends
Increase a bit.
Old Jul 7, 2005 | 01:10 PM
Kraest's Avatar
Retired
It would increase because you're higher in the RPM after every shift.
Mike
Old Jul 9, 2005 | 05:58 AM
Pro Built Automatics's Avatar
3rd gear is 1 to 1, 4th gear is .70. You can improve trap speeds by doing this. You will not slow down.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
