What exactly is the carrier?
Old Jul 14, 2005 | 04:55 AM
lil305gta's Avatar
Is it the housing for everything? I often get confused by this, rear ends are my wek point. If I have a series 2 carrier now, what do i need to make the swap to a series 3? I need help asap because i am getting noise from my bearings or differential. Thanks!
Old Jul 14, 2005 | 05:19 AM
SABLT194's Avatar
Re: What exactly is the carrier?
The carrier is the machined casting that the ring gear bolts to and the clutches (or cones), springs, and spider gears fit in to. The difference in carrier series 2,3,4 is the location of the ring gear bolting flange on the casting. I believe a 4 series ring gear flange is closer to the pinion than a 3 series, and a 3 series is closer than a 2.
Hope I've helped
Steve
Old Jul 14, 2005 | 11:32 AM
Bow94z's Avatar
The carrier is the "unit" on the left
Old Jul 14, 2005 | 11:52 AM
lil305gta's Avatar
Thanks fellas, I appreciate the fast responses!
Old Jul 14, 2005 | 08:33 PM
Gord's Green Z28's Avatar
Tell me that isn't your Dog's dinner. Talk about strong teeth.
Old Jul 14, 2005 | 08:47 PM
Bow94z's Avatar
he wants the pinion not my dog anyway
Old Jul 15, 2005 | 08:41 AM
lil305gta's Avatar
One last question before I order my gears.....which one will give me the best performance for my TPI 3.23's or 3.42's and who makes the best posi unit Auburn, Eaton, SLP,???? I'm up grading to a series 3 carrier.
Old Jul 15, 2005 | 10:13 AM
MyShibbyZ28's Avatar
I remember when i asked this same question....i got so much crap....
But now for your question. If you already have a posi unit and it's a 2 series carrier you don't have to get a 3 series carrier for a 3 series gear. If you stick the posi on end and measure up to the ring gear mounting flange you get the following measurement (using a tape measure)
2 series = 5 1/4"
3 series = 4 7/8"
The 3-series carrier locates the ring gear about .400" closer to the pinion since the higher ratio pinion necessarily has a smaller diameter than the gas mileage 2-series one.
A 3 series gear can be made to fit a 2 series carrier using a spacer, but it doesn't work the other way around. So just go get a spacer and throw it in between the gear and mounting flange. Then all you have to do it buy the gears and mount them. Hope this helped and didn't confuse you more.
ShibbyZ
Old Jul 16, 2005 | 01:19 PM
lil305gta's Avatar
Where can I buy the spacers? How much do they usually cost?
Old Jul 16, 2005 | 01:39 PM
lil305gta's Avatar
Should I replace the posi unit along with the bearings and gears? I don't want to spend unnecessary money if I don't have to. I am asking because I replaced ther bearings about 3 yrs ago and the noise from the rear has started again.
blkss01
Mar 29, 2003 02:36 AM
DTABFORMULA
Feb 28, 2003 04:56 AM
SnkEatr
Feb 24, 2003 11:30 AM
sideways_Into_3rd
Feb 16, 2003 12:24 PM
TransAm_Impostr
V6 Tech
Feb 15, 2003 07:15 AM
