Driveshaft ID
Old Jul 14, 2005 | 11:37 AM
ImNraged's Avatar
Driveshaft ID
How do I identify an aluminum driveshaft by looking at it? The reason I ask is, I just bought an LS1 driveshaft from Ebay. Before it got here, I was changing my trans mount and noticed the driveshaft was a clean silver color while the U-joints had the rusty look. When I recieved my LS1 shaft in the mail, it looked almost identical. Did I buy something I didn't need? Thanks.
Old Jul 14, 2005 | 11:43 AM
87DJP2001's Avatar
Re: Driveshaft ID
Sounds like you already have a Aluminum Dr Shaft and you just wasted your money.
Old Jul 18, 2005 | 09:36 PM
littlbasterd's Avatar
Re: Driveshaft ID
does a magnent stick to it???
Old Jul 19, 2005 | 09:50 AM
OutKast's Avatar
Re: Driveshaft ID
Hopefully the one already in the car is a 1LE which is stronger than the LS1 shaft.
Old Jul 19, 2005 | 02:16 PM
ImNraged's Avatar
Re: Driveshaft ID
Is it going to be either an 1LE or an LS1? I'm guessing there's no such thing as an LT1 aluminum driveshaft so that kind of narrows it down, huh? How can I tell for sure which one I have? Did any 96s come from the factory with aluminum?
Old Jul 19, 2005 | 02:24 PM
87DJP2001's Avatar
Re: Driveshaft ID
1LE & LT1 Aluminum Dr Shafts are one and the same 2 3/4' Dia.
LS1 Aluminum Dr Shafts are 3 " Dia.
Old Jul 19, 2005 | 02:33 PM
OutKast's Avatar
Re: Driveshaft ID
Don't let the size fool ya though. The LS1 shafts use a thinner gauge of aluminum tubing. Look closely and you can see the thickness HERE
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
