New eaton posi/gear install
Old Jul 17, 2005 | 09:35 PM
96Z28TealM6's Avatar
I have a question. Does the car need to be driven hard in order to break in the new eaton posi/gears or can it be driven regularly to be broken in.
Old Jul 18, 2005 | 04:11 PM
slomarao's Avatar
Re: New eaton posi/gear install
just drive it normal for a few times and your good to go.
Old Jul 18, 2005 | 04:49 PM
ok thank you
Old Jul 18, 2005 | 05:20 PM
Z28Nut's Avatar
Follow the instructions that came with the gears or contact the manufacturer to find out. The Richmonds I used said to drive for 10mi. then let it cool for 30min. Repeat several times w/out jumping on a freeway or romping on the throttle. New gears will run very hot until they break in so extended high speed driving is not good for a brand new set. I learned this the hard way Also change the gear lube after 500-600mi, your new bearings will love you
Old Jul 18, 2005 | 06:25 PM
I won't be able to change the lube after 600 miles..I'm leaving Sunday morning to Louisiana for 2200 mile trip
Old Jul 18, 2005 | 07:24 PM
Z28Nut's Avatar
Guess your bearings ain't gonna love you after all . . .
I'd recommend stopping on the way and getting it changed. As the gears break in they will put a lot of metal particles in the lube and the longer they stay in there, the more wear you will have on everything in the rearend.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
ddr698
Jan 9, 2015 10:05 AM
wytblur
Mar 2, 2003 03:40 PM
