so the 4L60E will shift into 2ed at 100mph
Old Jun 29, 2005 | 10:29 PM
anasazi's Avatar
so i'm coming back tonight down a fast road and i put it in "D" for some high speed fun. well when it came time for the fun to end i went to push it back into OD but instead accidentally tapped the shifter while my hand was going back and shifted into 2.
to my surprise it shifted
i quickly shifted back into OD and all was good. RPM's didn't go past redline but it sure did scare the crap out of me.
Old Jun 29, 2005 | 10:39 PM
CrabhartZ28's Avatar
Re: so the 4L60E will shift into 2ed at 100mph
it'll shift into 1st if you tell it to. these late model A4s will stay in 1st and will stay in 2nd/start in 2nd if you put the shifter in that position.
Old Jun 30, 2005 | 05:41 PM
MISOMWS6's Avatar
Yeah, I guess with 273's it could be right around there, with my 323's it shifts into 3rd at WOT around 85mph.
Old Jul 1, 2005 | 04:35 AM
slowpoke96z28's Avatar
it will shift into second anytime you select that gear.(and it'll tear you engine up, too, if you let it)
most 4L60E strategies will command an upshift to second if you try to select first at too high a speed. but it will give you second whenever.
Old Jul 2, 2005 | 12:43 AM
Is that right? I don't want to test it obviously, but i'd sure hope it would have some sort of fail safe for that situation.
Old Jul 2, 2005 | 01:02 AM
no fail safe for second gear, bro.
Old Jul 2, 2005 | 01:08 AM
I know it doesn't, but i'd hope it would have one for first, which is what you said correct?
Old Jul 2, 2005 | 01:29 AM
the PCM will not allow 1st gear form manual 2nd unless the car is < 30 to 35 mph. if its faster than 35, the PCM will hold second gear instead, even though the shifter is in first.
Old Jul 2, 2005 | 12:35 PM
CamaroSS30thAnn's Avatar
my car with 3.23s will shift 1-2 at 35 2-3 at 77 if u have 2.73s its possible but im not sure
Old Jul 2, 2005 | 02:06 PM
we are discussing WOT downshifts not upshifts. those upshifts sound about right though.
Parts Wanted
May 1, 2016 10:25 AM
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
football4life
Oct 4, 2015 07:48 AM
marlar98
Sep 19, 2015 07:53 AM
