6 speed swap
Old Jul 17, 2005 | 12:25 PM
z28_4life's Avatar
6 speed swap
Would it be worth it to swap the harnesses as well or would it be easier to just order the certain wires i need to convert and just splice and soder. I only ask because i'm half way through taking off my auto harness but haven't gotten under the dash yet to start having real fun? Should i keep digging and put the manual harness in or just stop where i'm at
Old Jul 17, 2005 | 12:28 PM
madwolf's Avatar
Re: 6 speed swap
I used a manual transmission harness. You have to use the same year harness or else it gets complicated. This will make things easier, but you will still need to wire the reverse lockout solenoid separately.
Also, I only used the engine harness. It won't be worth the time and effort to swap out interior harnesses as well.
If you're good with wiring, it won't make that much of a difference though. I had to change harnesses either way due to other reasons.
Old Jul 18, 2005 | 10:18 AM
z28_4life's Avatar
Re: 6 speed swap
Well, found out his year was a 95 so looks like i'll be putting the whole harness back in . What all do i exactly need now to set upmy harness to the new t56. I know you said i had to wire up the reverse lockout solenoid. Do I have to special order anything from a dealership/summit or could i get the stuff at any local auto parts store?
REDNECKISBOSS
Apr 17, 2015 07:14 AM
alex5366
Mar 27, 2015 03:30 PM
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
Jul 4, 2005 05:00 PM
