Replacing clutch, any details I should know about?
Old Jul 11, 2005 | 12:13 AM
Meccadeth's Avatar
I'm replacing my stock clutch, flywheel and slave cylinder tomarrow. I've been researching what all I need to do on install university...
http://installuniversity.com/install...r_cylinder.htm
http://installuniversity.com/install...ch_install.htm
Are there any other details that they left out that I should know about before getting started? I guess some people said they just "bench pressed" the transmission out instead of using wood stacking strategy. I also have to "clean" the clutch, how do I do that? How do I "bleed" the clutch lines exactly? Any other help & tips is appreciated...
Old Jul 11, 2005 | 08:51 AM
teke184's Avatar
Re: Replacing clutch, any details I should know about?
what kind of car?
on my LS1 trans there is a bleeder screw on the driverside of the trans, right were the bellhousing bolts to the trans, kindda up on the top in the trans tunnel.
i was able to do my clutch for the most part alone wiith just a floor jack.
use brake cleaner to clean the clutch, flywheel etc...
what clutch/fw are you going with?
Old Jul 11, 2005 | 12:04 PM
Meccadeth's Avatar
'99 Z28
I went with a Z06 clutch, pressure plate, slave cylinder, and flywheel.
Old Jul 14, 2005 | 09:06 PM
Meccadeth's Avatar
Any advice on taking out the top two bolts connecting the bell housing to the tranny?
Old Jul 14, 2005 | 09:49 PM
nateh's Avatar
I've done this a couple of times and had very little trouble with the top two bolts when I loosened the transmission mount bolt and let the whole thing sag a little on the engine mounts. I put a floor jack under the rear of the transmission and let it down. Then I used a long extension to reach the bolts. It was a lot easier than I had thought it would be.
Old Jul 15, 2005 | 02:17 PM
Meccadeth's Avatar
My tranmission won't "sag" any...it just stays in the same place I've taken out the driveshaft, crossmember, upper torque arm mount, torque arm mount, and transmission mount and i'm still not getting any play.
I got the top driver side one out but this passenger side one is going to be impossible given my current circumstances....you think it would be practical to just take all the rest of them out and kind of twist the transmission clockwise a bit to give me more clearance?
Old Jul 15, 2005 | 05:32 PM
nateh's Avatar
I know one person who used a pry bar to move the floorpan up just enough to give clearance for the socket. You must have much firmer mounts than came stock on the car. When I undo the trans mount, the whole thing rotates and the rear drops a couple inches. This gives clearance to the bolts.
Some people get to the bolts through the shifter hole from inside the car. You might try that.
Good luck.
Old Jul 15, 2005 | 07:20 PM
97z28/m6's Avatar
is a LT1 any different than the install above?doing it this weekend.
Old Jul 15, 2005 | 09:42 PM
Meccadeth's Avatar
I think it might actually be easier getting to the passenger side top bolt from the driver side....I'm getting some more extentions tomarrow and I'm gunna try that out...I can actually see it from the driver side.
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
Jazsun
Dec 29, 2014 12:14 PM
