New Clutch, need to replace throwout bearing??
Old Jun 30, 2005 | 09:31 PM
Silvershark's Avatar
I bought a spec stage 4 clutch and I was curious if it is necessary to install a new throwout bearing.
My old tranny/clutch never made any noise.
Old Jun 30, 2005 | 09:40 PM
Robs97Z28's Avatar
Re: New Clutch, need to replace throwout bearing??
You always replace the throw out bearing. If it were to fail, you will have too pull everything back apart.
I believe that the pressure plate comes pre installed with the throw out bearing. you will need to buy and replace the pilot bearing.
Old Jun 30, 2005 | 09:42 PM
OBE1 95Z28's Avatar
Yes, the bearing should be replaced.
Old Jun 30, 2005 | 09:43 PM
Whats the bearing inside of the flywheel? Is that the pilot bearing? I guess maybe I am not clear on the two. The clutch came with a install tool, pressure plate, disc and this bearing that is 1 1/8" outside diameter and roughly 5/8" inside diameter.
Old Jun 30, 2005 | 09:46 PM
Robs97Z28's Avatar
That is the pilot bearing. I had one fail about 5000 miles after a new ckutch was installed. Everything had to come back off to replace a $10 part. make sure the bearing is greased, too.
Old Jun 30, 2005 | 09:49 PM
Ok, it looks like the new clutch kit came with a new pilot bearing then? Cause my old one is bronze looking and this new one from spec is silver. However, my stock clutch was just replaced really recently and the pressure plate and the discs and everything look almost as new as my new spec stage 4. I simply am replacing the clutch system because the clutch wouldnt be able to handle the HP.
So basically I should be able to just use the install tool and put in the new pressure plate, disc etc.
Old Jul 1, 2005 | 11:52 AM
A polite heads up and a request that you post on the correct forum. You're on "LT1 Engine Tech"...... moving to "Drivetrain"
MyfateZ28
Jun 19, 2015 03:42 AM
BPS
9
Mar 5, 2015 10:51 PM
grabbem88
Feb 17, 2015 07:49 AM
HectorM52
Jan 30, 2015 11:08 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
