how hard is it to drop the rear end...
Old Jul 13, 2005 | 10:38 AM
glennxx1's Avatar
and put a 9'' up? do you have to fab the 9'' or if its for an F body it should bolt right up?
Old Jul 13, 2005 | 10:41 AM
turbo_Z's Avatar
Re: how hard is it to drop the rear end...
If you have one built for an Fbody then it should bolt right in. The only potential problem I can see is if the DS doesnt fit.
Old Jul 13, 2005 | 11:18 AM
glennxx1's Avatar
doesnt fit in teh groove beside the torq arm or doesnt fit from the tranny to the rear end?
Old Jul 13, 2005 | 04:57 PM
Z28Nut's Avatar
The length of the driveshaft will be too long, I believe. You'll need to bolt in the 9" and then measure the actual distance between trans and pinion yoke. Talk to whoever is going to make or modify your driveshaft to find out exactly where to measure from.
Old Jul 13, 2005 | 05:15 PM
ABA383's Avatar
...Also remember that the center section of the 9" is slightly off center towards the driver's side. This will move the rear TA mounting point and the TA will be "cocked" a little, meaning that the front and rear mounting points will not be in a straight line and may cause excessive wheel hop and suspension binding, This can be remedied by an aftermarket TA with the appropriate mounting holes (Spohn, BMR, etc...), or by fabbing up your own offset mount...
--Alan
Old Jul 13, 2005 | 10:55 PM
Z28Nut's Avatar
Now I'm definitely thinking I made the right choice with a DTS 12-bolt. More efficient power transmission, same DS, no having to offset TA and still GM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
blac94Z
Mar 2, 2015 06:03 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Alex Barnes
Jan 24, 2015 10:21 PM
