1995 Z28 Gears Shifter
Old Oct 12, 2006 | 11:51 PM
ROUDA's Avatar
On a 1995 Z28 gear shifter is there a first gear on the shift selecter or is it have 2, D, overdrive,N, R, P. Or does it have 1,2,D,overdrive,N,R,P.
Old Oct 13, 2006 | 12:09 AM
LT1 POWR's Avatar
Re: 1995 Z28 Gears Shifter
If you have a 2.73 gear in the rear you wont have a 1st, so it will be 2,D,overdrive,N,R,P.
Old Oct 13, 2006 | 11:47 AM
ROUDA's Avatar
why is it like that. they are 273 gears
Old Oct 13, 2006 | 12:14 PM
Sgt. Spuds's Avatar
Federal noise laws were violated when the car was ran in first gear only with the 273's or something like that, so if the car was in 1st gear through the rpm range, it got to loud.
Old Oct 13, 2006 | 08:54 PM
ROUDA's Avatar
Are Those Gears Good For Speed Or Cruising
Old Oct 13, 2006 | 09:38 PM
LT1 POWR's Avatar
Lower gears, like 2.73 are good for gas milege and top speed. Higher gears like 4.10+ are good for drag raceing, if you can get traction.
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
Jan 5, 2015 07:14 PM
pete53
Dec 9, 2014 07:31 AM
