Clutch leaks fluid inside car onto foot. How to fix?
my friend dropped my ending without disconnecting the slave cylinder from the bellhousing of the tranny. So basically it ripped the metal braided line from from the plastic plunger assembly... Well i fixed that by putting a new plunger on because that was damaged not the braided line...
i later pressed in the clutch with the car off and some fluid dripped down onto my foot.
THe clutch was hard to press down with the car off...
I forget if the clutch is always suppose to feel pretty easy to push in or when its off it gets harder...?
Re: Clutch leaks fluid inside car onto foot. How to fix?
yeah definately time for a new master, im there right now, wel mine never squirted fluid at me but its drippin down a bit. and is really funy about how it goes in. mines bad enough i thought my new trans was already shot..
i was happy when i discovered i had almost no clutch fluid left lol.
clutch master cylinder
fun job
i hope you have thin girlish hands
i got so frustrated on my third gen i removed the steering column to change the master
4th gens are similar
fun job
squarehead
Nov 21, 2014 08:02 PM
