neutral + clutch in = stall
As the title says. When Im in gear OR neutral and push the clutch in, the call shakes violently and dies. I also cant start the motor by pressing in the clutch.
Ive done some reading and Im pretty sure the bolt that holds the clutch fork down came loose.
Does this sound right to anyone else?
(This is a Ram Powergrip HD clutch on an LT1)
Re: neutral + clutch in = stall
Not sure I understand the question. Will the "clutch" move back and forth? You mean the shifter? Pedal?
No, the clutch doesn't move. It's clamped in there pretty tight between the flywheel and pressure plate. But I really don't think that's what you're asking.
ricks95TA
Jul 23, 2015 12:59 AM
ducttape1975
Jul 10, 2015 06:29 PM
