help me choose a clutch setup
Old Oct 5, 2006 | 05:57 PM
95LT1conv's Avatar
i know this is in the wrong forum, but i need some help fast. i just burned up a spec 1 in less than 10k and need a new setup. should i order a cheap setup just to use the PP and get something like a McCleod disc or should i just get a kit like Luk or Ac delco. i can get a Luk stage 2 kit for around $400 and i can get the AC kit for $340. Both kits include everything you need. im leaning toward getting the cheaper kit just for the PP and T/O bearing and then using the McCleod single disc. help me decide.
thanks ,
chad
Old Oct 5, 2006 | 09:06 PM
95LT1conv's Avatar
Re: help me choose a clutch setup
noone can help?
Old Oct 6, 2006 | 10:32 AM
QUASARBLUEZ28's Avatar
Either of those will work, or check out Hays kits. Supose to be a step better than stock. You can get just a disc from Jegs or Summit for less than 90.00 $, if your other parts are in useable that would be a quick fix. I am going that route while my S.T. is heading out for a rebuilt.
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jan 30, 2015 11:08 PM
Duke
Jul 31, 2002 05:13 PM
