conversion fittings for braided trans lines
I don't remember on the 4L60E, but if the fittings are the same style as on a 200-4R...
then you need a 1/2-20 to -6 AN adapter fitting, Earls part no. EAR-991946ERL (Summit, $5.95). This is an inverted flare fitting. These fittings thread into the existing case fittings on the side of the trans. This is what I'm gonna use on my GN's 200-4R.
Or you can ditch the trans case fittings altogether and use standard 1/4" NPT to -6 AN (male) adapters. Though this works too but it's usually not recommended because you risk cracking the trans case if you overtighten them and will leak. Thats because the threads in the trans case are straight and the adapter fitting is tapered.
But I have a friend who cracked his case doing the same thing.
I was going to do that but the threads aren't right....thats why it cracks the case
Has anyone used the quick connects? I think they come from biondo
Would it be any better to tap the holes with a 1/4 npt
I'm just wondering...I will be doing this within the next 2 weeks
Use the Earls adapters I mentioned in my first post. Screws into the existing brass fittings on the trans case so you don't need to worry about cracking the case. Then you can attach any -6 AN line to the trans....
http://store.summitracing.com/partde...0&autoview=sku
i got my fittings from the local earl's store here in town, they fit perfect from the trans case to a -6 line
for the best flow you must ditch the stock fittings,, why use 3/8"-an-6 lines if your fittings on the trans are still 5/16",,, makes about as much sense as using 3" exhaust then 2" tail pipe,,lol
Anyway, got a part number for the fitting you used? I have yet to find the correct straight thread fitting for the trans case.
I used these 45's and will run -6 braided over to the frame and I have hard tube going to the front and all that goes to the cooler
1/4 npt to -6
Hope it helps, Also this is the clearance with a madman dipstick on a TH350
1/4 npt to -6
My setup is exactly like mdacton's pictured above. I've used these on two different trannys with no problems. Just don't tighten the crap out of them, they don't need to be super tight with the teflon tape.
I agree they don't need to be super tight that swhy people crack the cases.
I got them tight by hand and then only needed about 1/2 turn to get em where I wanted. I used permatex PTS with teflon.
I like those Biondo quick connects but I don't have the monet for them right now
