Does gears cause stress on trans?
Old Oct 28, 2006 | 08:06 PM
z2894droptop's Avatar
Will it cause my trans to work harder if I go from 3.73 to 4.56 gears? Just aking because I want to know if I have to upgrade my trans over a gear swap.
Old Oct 28, 2006 | 10:25 PM
MyShibbyZ28's Avatar
What are you using 4.56 gears for? You will be around 3k rpm in overdrive. No it does not really make it work harder, just spin more.
Old Oct 30, 2006 | 09:47 AM
FirstYrLS1Z's Avatar
To answer the question,going to a higher numerical gear(3.73 to 4.56) will create a higher mechanical advantage between the engine,trans,driveshaft,u-joints versus the carrier and axles.A higher mechanical advantage reduces stress on those parts before the gears and increases stress on those parts after the gears.
Old Oct 30, 2006 | 01:22 PM
Capn Pete's Avatar
Here's a question ... auto or standard????
Old Oct 31, 2006 | 04:20 PM
This is a track only car. It will be at 130mph at 6800rpm's with 29'' tires in drive.
Old Oct 31, 2006 | 04:22 PM
Auto
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Cam's maro
Jan 30, 2015 09:21 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
