? LS1 Rearend in LT1
Old Nov 1, 2006 | 02:49 PM
Red on Red WS6's Avatar
A Buddy has a 2000 SS Camaro that was wrecked and i was wondering if there is any issues i will have with swaping rearends. His has 3:73 gears mine has 3:23 gears this is the main reason for the swap. Will i have any problems with my ABS breaks?
Old Nov 1, 2006 | 08:21 PM
My Iroc Z28's Avatar
Nope, As long as it has the same abs setup as you, you will be fine. I have a 00 SS rearend in my 97 it bolted right in. You will need the parking brake cables & bracket from the donor car.
Old Nov 2, 2006 | 12:37 AM
Thanks for the reply how can I tell if it is the same ABS or not?
Old Nov 2, 2006 | 04:09 AM
If you don't have traction control & and the donor car does then they will be different. If Both cars don't/do have traction control then it will work.
rideordie
Nov 5, 2019 04:52 PM
ddr698
Jan 9, 2015 10:05 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
