Crazy Sound NEED HELP PLEASE
Old Oct 20, 2006 | 06:55 AM
farva's Avatar
I have a 2000 Camaro SS with a ls1 350 and a 6 speed manual (i think a t-56 it is the origional trany). 65000 origional miles. All parts origional. There are no aftermarket parts on my car other than air filter and oil filter. I was attempting to pass a slow truck on a back road in germany. i was traveling at about 35 mph. i was in fourth gear at the time. i downshifted into third and stepped on the gas. i pressed it about half way to the floor. when i did this i imediatly heard a loud screatch. it sounds like two pieces of metal scraping against each other. i pressed the clutch to the floor and it stops. i can still press the clutch but it goes to the floor with slight pressure. i can shift the car into gear and ease the clutch out to move. i have to go down hill or up hill by easing the clutch out. if i press the gas even slightly while the car is in gear it will screatch. the engion remains normal. oil temp and alteinator. i need to know if this has happened to anyone else out there. i was told possibly the transmission, the clutch, the throw out bearing, or the splines on the back of the transmission that link with the axil.All gears still work. 1-6 and reverse. please help me. i want my car on the road again.
army aviation all the way.
Old Oct 23, 2006 | 02:21 AM
farva's Avatar
Re: Crazy Sound NEED HELP PLEASE
i was told that a spring in my clutch may have broken but i am not sure. any ideas???
FredM
Exhaust System
Feb 8, 2016 02:10 PM
95craz28
11
Sep 12, 2015 07:47 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
mlopezart
Sep 8, 2015 12:15 PM
GT what?
Jul 14, 2015 10:17 PM
