Do the wheels have to be off to get the c-clips out?
yes, wheels off, brakes off, rotors off, cross pin bolt and cross pin removed, push in axles and c-clip will fall out then pull the axle out do the same for the other side, then take out the diff main cap bolts and the carrier will pry out , then take it to your work bench and take off the old reluctor ring and install the new one
if you have never done a ring and pinion install of diff work its probly not a job for you
Its best to use a stick magnet to get the C clips out, very frustrating without one.
Once you get the axle pushed in its a matter of seconds to pull the Cclip out or install one with a magnet.
30th Anniv Z28
Aug 1, 2015 10:39 AM
jasonduaine
Jun 4, 2015 09:29 AM
