drag radials
Old Nov 1, 2006 | 08:16 AM
ColeSmith's Avatar
drag radials
Didn't know where to put this so move if needed, but if I put Nitto 555s on my car which has 101K will the rear end hold up?? Thanks
Old Nov 1, 2006 | 08:22 AM
davidz28guy's Avatar
nittos arent super sticky, plus you have an auto, so it should be fine, but ive busted 2 rear ends on street tires and i have an auto as well, so who knows
Old Nov 1, 2006 | 11:45 AM
sandman63's Avatar
Can you afford a new gear end? Not saying it will blow, am just saying that if it does.
Old Nov 1, 2006 | 11:46 AM
sandman63's Avatar
opps, REAR end, lol.
Old Nov 1, 2006 | 12:06 PM
2000GTP's Avatar
Its always a hit or miss with that issue. Personally, I wouldn't worry too much since you are using Nittos and you have an automatic tranny. If you had an M6, Mickey Thompson DRs, and the urge to do high rpm clutch drops, then I would start to worry a little more.
Old Nov 1, 2006 | 04:39 PM
ColeSmith's Avatar
NO, I cant. Is the risk worth the reward?
Old Nov 1, 2006 | 05:17 PM
2000GTP's Avatar
Probably not then.
Old Nov 1, 2006 | 05:35 PM
CamaroRacing12's Avatar
<<<wants to do m/t et streets on my stock 10-bolt 95k miles A4.....will only be launching from 1500rpms tho....for now.... safe or not?
Old Nov 2, 2006 | 01:30 PM
depends on your luck, like i said i have a 95 its an auto, has 96k miles on it, on street tires i destroyed my stock posi, then on a rebuilt 10 bolt i snapped a chunk off my pinion gear, now with mickey thompsons im sure i wouldnt have lasted as long as i did, but you might be alright, plenty of autos run drs with out destroying the stock rear end, i just have really bad luck
Old Nov 2, 2006 | 01:36 PM
myslowcamaro's Avatar
gotta ask yourself that with every mod. sticky tires, n20, too much boost, etc.
Old Nov 2, 2006 | 04:06 PM
speed_demon24's Avatar
If you have an auto you should be fine.
I'm a 6-spd with over 500rwhp on nitto's on a 10 bolt. But at my power level I just spin the **** out of them, some BFG's are next for me.
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
