Possably a broken input shaft?
Old Oct 18, 2006 | 01:06 PM
'94 Bad A Z28's Avatar
What would be the easiest way to tell if you have a broken input shaft besides pulling the trans? My car has no forward gear, but reverse works just fine. If I down shift the car to 1st gear it will attemp to go in to gear but will still be in nutral. The tranny fluid is as close to perfect, in color, as it can be. Just want to consider every possability before getting a new trans.
Old Oct 21, 2006 | 11:43 AM
Re: Possably a broken input shaft?
Anyone?
Old Oct 21, 2006 | 03:11 PM
respectirocz's Avatar
the input shaft is connected to the clutch disc, if you can move the car in reverse, the input shaft is fine, see if you can start the car in any other gear, if you can, then you probably have a messed up synchro
Old Oct 22, 2006 | 07:14 AM
Pro Built Automatics's Avatar
If you have reverse, the input shaft is still good. Did this happen all at once?
Old Oct 22, 2006 | 11:08 AM
At first if I put the gear selector in 2nd gear it would go in to gear and I could manually up shift the car, but if I more than moderately accelerated the car would slip out of gear. Then oneday I just stabbed the gas in my driveway and I felt something "let go" and it's had no forward gear since then.
Old Oct 22, 2006 | 03:32 PM
i didnt read your sig in my last post and i realize now its an automatic, not a stick, so disregard my last message
if i could find my powerflow chart for the 4l60e i would be able to help you figure out which friction material is slipping, but i dont know so you'r better off asking cpt, but then even if you found out which friction material is slipping, your gonna need a rebuild anyway
Old Oct 23, 2006 | 01:09 AM
You have lost the forward clutch, possibly the forward clutch piston cracked (early 4L60E's used the aluminum forward piston) you can replace the forward & overrun with the molded rubber steel pistons. Depending on what you want to do during the rebuild, you could do some upgrades here. If I can be of help, let me know?
Old Oct 23, 2006 | 02:53 PM
I can't really afford to do anything with it right now, I'm just trying to figure out what happened.
Ericksd
Jan 20, 2016 06:07 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
