10 Bolt ?
Old Nov 5, 2006 | 06:22 PM
suprsiz3_ls1's Avatar
10 Bolt ?
I'm in the process of buying a replacment rear-end, the one i'm looking at the guy doesn't know what year camaro it's out of. He says he thinks it's out of a 98 but on his information post he says it will fit in a 95 or newer. First question, if my camaro is a 2002 model does it matter if the rear-end comes out of a 93-2002 model, and would any year rear-end work in my car(93-2002)? My camaro doesn't have traction control, so does it matter if his did have traction control ,and would everything still work the same on my car(ABS)? Last question, could i swap the differentials out of his 10 bolt into my 10 bolt?
Thanks for your help!!
Old Nov 5, 2006 | 07:20 PM
Dave89IROC's Avatar
93-02 will bolt in, you need to stay with trac or no trac
the rear brakes are different 93-97 and 98-02, but they will swap I believe
and yes, you can swap the carrier/gears if so desired
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
