How do you remove the ring gear?
Old Oct 30, 2006 | 12:27 PM
crazypurgatory's Avatar
Question How do you remove the ring gear?
What is the easiest way to remove the ring gear off the Carrier?
I'm putting a posi carrier in my 1971 Camaro and I have know idea what to use to get the gear off without damaging the carrier.
Thanks,
Chris G.
Old Oct 30, 2006 | 01:20 PM
Capn Pete's Avatar
Loosen all the bolts off, but leave them partially threaded in, and tap the ring gear off by hitting the bolts. Just go a little at a time, and keep un-threading the bolts more as you need to. This should work the gear off the carrier no problem .
Old Oct 30, 2006 | 02:15 PM
Lightbulb
Thanks I will give it a try.
I was also told that I could heat the gear with a propane torch and it would come off too.
Chris G.
Old Oct 30, 2006 | 08:14 PM
Lightbulb
Well I got the ring gear off the posi carrier.
Funny thing is that the gears are not a matching set.
So I have a 4.555555555555555 gear set.
The ring gear has 41 teeth and the pinion has 9 teeth.
I was not going to use those gears any way just the posi carrier.
I guess I can make a picture frame out of the ring gear.
Thanks agine,
Chris G.
Old Oct 30, 2006 | 08:39 PM
Capn Pete's Avatar
Yeah, that's 4.56's ... what's the problem??
The gear popped off no problem though?
Old Oct 30, 2006 | 08:54 PM
Yep know problem.
When I got my 1971 Camaro the guy gave me a use Positraction Carrier witch I wanted to use so I had to take the gear off it.
I might change them down the road but not now.
Is there a way to tell if these gears are a matching set?
Thanks,
Chris G.
Old Oct 30, 2006 | 09:31 PM
Capn Pete's Avatar
Did the diff work?? 41/9 is the correct combo for 4.56's, so I wouldn't suspect anything wrong . If the diff did not turn, or made noise or something, then perhaps they might not be a matched set. Otherwise, I wouldn't think there's a problem with it .
Old Oct 30, 2006 | 10:04 PM
Lightbulb
Well I haven't put it in yet I might do it tomorrow.
As long as the Positraction works all should go well I just have to swap out the ring gear from the non Positraction carrier that's in the car right now.
I was doing 100 foot burn outs with the one wheel wounder so I hope it hooks up or does a 100 foot two wheel bur out.
Thanks again,
Chris G.
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
4586
Jan 3, 2015 07:22 PM
97SSdude
Dec 31, 2014 07:43 PM
