RIP 10bolt
Old Oct 23, 2006 | 02:54 PM
GhostZ28's Avatar
RIP 10bolt
I sent my rear to the grave last night.. And thats all on factory internals, just minor bolt-ons so far. I'm with a new friend of mine who is a rice burner lover, so i said "Whats the fastest car you've ever been in?" right about the time he replied, i gunned it in second and CLANK, THUMP THUMP THUMP.. I thought it was the driveshaft at first, then when i realized nothing was hanging and it wasnt an engine problem....
So now what to do.. This kinda forces me to FINALLY get on my H/C project, but now i need a good rear end. I was thinking of going 9" because I hear you can build one to support like 500BHP and up to high 10's for cheaper than a 12 bolt.
what do you guys think I should do? Upgrade to a 9" or 12 bolt? should I just fix whatever is broken and rebuild it?
I'm on a bit of a budget, I still have about 400 dollars worth of oil pump and gaskets and fasteners to buy before i can install my H/C. But I think I might be able to afford 900 dollars or so more. Thanks for the help and suggestions guys.
Old Oct 23, 2006 | 03:01 PM
SSpdDmon's Avatar
Re: RIP 10bolt
I'm on a bit of a budget, I still have about 400 dollars worth of oil pump and gaskets and fastenerd to buy before i can install my H/C. But I think I might be able to afford 900 dollars or so more. Thanks for the help and suggestions guys.
If you can find a way to put a 9" together for under $1K, please let me know. I'm not all that excited with the $2K+ price tags out there...
Old Oct 23, 2006 | 03:05 PM
GhostZ28's Avatar
Re: RIP 10bolt
I don't know if I'll be able to build one for under a thousand, but at least I've been told that It can be done for under or at the cost of a 12.
Old Oct 23, 2006 | 03:23 PM
SSpdDmon's Avatar
Re: RIP 10bolt
Well, if it can be done without costing an arm/leg, I'd say call Scott (1BAD86Z). He's local to me, but has his hands in rear ends from coast to coast (pun intended).
Old Oct 23, 2006 | 03:39 PM
GhostZ28's Avatar
Re: RIP 10bolt
hahaha! I just drove it and it only clanks twice a revolution of the wheels only in gear of course, but it clanks HARD. I only drive it about 50 feet then parked it. does that sound like the axle shaft or whatever or the ring and pinion gears?
Old Oct 23, 2006 | 04:42 PM
Sparkz28ss's Avatar
Re: RIP 10bolt
Ring and pinion..... sans some teeth
I had a friend do that to my SS....called me from his house " I killed it...but I made it home!"
Old Oct 23, 2006 | 08:32 PM
GhostZ28's Avatar
Re: RIP 10bolt
thats the same reaction I had. My friend was in the car with me and was totally suprised that i wansnt angry, and that I was laughing. I told him, "this happens to even stock camaros all the time. Plus I was being stupid so we should both be laughing"
Old Oct 23, 2006 | 09:04 PM
myslowcamaro's Avatar
Re: RIP 10bolt
i see the 9" are cheaper than the 12 bolt, but dont the 9" setups need some sort of abs setup in addition?
Old Oct 23, 2006 | 09:23 PM
GhostZ28's Avatar
Re: RIP 10bolt
yes, but I'm going to do my research and ask the drivetrain guys what I should do. I think I can do all the work to make a 9" possible.
Edit: thank you mods for moving it.
Old Oct 24, 2006 | 03:10 PM
GhostZ28's Avatar
bump. anyone have suggestions?
HibachiZ28
Nov 6, 2015 12:53 AM
IndyZman
Oct 22, 2015 02:17 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
