Transmission Question
That's because the person who ordered the car did not check the option box for the "performance rear axle" option. As a result, it got a small plastic tab that blocks the selection of "1" (can easilly be removed), the indicator window without the "1", a 2.73 rear axle ratio (instead of 3.23), a 110MPH speedo (instead of 155). Typically, also no Z-rated tires and a speed limiter in the range of 108-115MPH (instead of 255 with the Z-rated tires).
