Replacing transmission mount?
Old Oct 18, 2006 | 05:03 PM
reamo04's Avatar
Well guys, my tranny mount is shot. Now, I am buying a prothane tranny mount (the extra vibration doesnt bother me), but I am wondering what do I do to get to the old one to replace it?
Old Oct 18, 2006 | 05:11 PM
CamaroSS30thAnn's Avatar
Re: Replacing transmission mount?
its very straight forward
4 bolts for the crossmember and 3? for the mount
bolt the new one up and put the crossmember back on and ur good
Dennis93TA's Avatar
All you need is a jack, and jackstands, or car ramps. Then unbolt the center bolt that connects the mount to the crossmember. take a jack and lightly jack the tranny under the tailshaft until it is supported by the jack. Then take off th four bolts holding the crossmember on. then the two bolts for the mount itself. reverse process and done.
edit: oh and the vibration isn't even noticable if you have a good balanced drivetrain. Mine vibrated like hell until i got a new torque converter. Now it's just like stock, but a lot stronger.
Old Oct 18, 2006 | 06:01 PM
seawolf06's Avatar
Leave the crossmember a little loose when you're setting the tranny back down onto it so that you can move it around to get the bolt back in the hole. Also, make sure you don't over tighten the stud for the mount because it WILL break off. Ask me how I know!
rjc1629
Jan 27, 2015 10:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Cam's maro
Dec 28, 2014 09:30 AM
Jul 4, 2005 05:00 PM
