Slave cylinder?
Old Nov 4, 2006 | 07:30 AM
chris96camaro's Avatar
Slave cylinder?
My car slowly loses brake fluid from the clutch master cylinder. I don't see fluid where i park, and I do not know where the leak is coming from. The pedal drops slightly somtimes, but the pedal stiffens up when I add more fluid. I am thinking it might be the slave cylinder. I dont think its the master cylinder, but I am not sure on this one.
Would i be able to see the fluid on the ground if it was the slave cylinder? And has anybody had this problem before?
Old Nov 4, 2006 | 02:48 PM
MEAN LT1's Avatar
Yes to both.
Old Nov 4, 2006 | 07:01 PM
Then do I have to have the tranny out of the car to replace/check the slave cylinder?
And if someone else has had the problem, what was the cause and how was it fixed?
Old Nov 6, 2006 | 01:04 PM
Anybody?
Old Nov 6, 2006 | 04:12 PM
Mikey97Z's Avatar
The slave cylinder can be removed from the tranny with 2 bolts. You can inspect it if you look under the car.
Old Nov 7, 2006 | 09:32 AM
OBE1 95Z28's Avatar
The slave cylinder has a rubber boot over the actuator rod that can catch leaking fluid and keep it from hitting the ground. As stated above, you can remove the slave cylinder by remove 2 nuts. Just don't press down on the clutch pedal while the slave cylinder is unbolted from the car. My local parts store carries a replacement slave cylinder for about $70.
Old Nov 7, 2006 | 12:35 PM
respectirocz's Avatar
its recommended to disconnect the rod on the master cylinder from the clutch pedal so you dont put any pressure on the slave cylinder
Old Nov 11, 2006 | 11:27 AM
I didnt mention that the motor is a 3.8. Does that change anything that has been mentioned so far?
Old Nov 13, 2006 | 07:29 PM
anybody?
Old Nov 14, 2006 | 07:52 PM
Come on...anybody?
Old Nov 22, 2006 | 06:34 PM
Can someone help me? I need to know where the slave cylinder is on my 1998 3.8 camaro.
Old Nov 22, 2006 | 07:54 PM
Will I have to pull the tranny to replace it?
Old Nov 23, 2006 | 07:31 AM
mdacton's Avatar
3.8 i'm pretty sure you have to take the trans out, it hs a hyd. t/o brg. kind of like a ford
chack a service manual, you should be able to see some fluid in the bellhousing. you will have to bleed it when you put it back in
when you have it out you may want to check your clutch/rear main
Old Nov 26, 2006 | 10:29 PM
IndyTruck's Avatar
Yes, the 3.8 slave is actually a hydraulic throwout bearing, similar to an LS1 car. You have to pull the trans to get at it. I'm putting a clutch in my kid's car right now, and I'm changing the slave just so it's new and I don't have to worry about it. New (rebuilt) ones are ~$80
HTH a little
kevin
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
