Mcleod ST flywheel balancer weight
Old Nov 1, 2006 | 09:36 PM
ponyackn's Avatar
I have a Mcleod ST with the steel flywheel. I'm installing it with my new 383 built by VRE. I noticed that it still has the weight attached to the flywheel. Should I remove it or is there some particular measuring involved that requires more than me simply unbolting the weight?
I used this same clutch and flywheel previously with my cammed stock block but never realized that a weight was there because I didn't install the clutch.
Old Nov 1, 2006 | 11:41 PM
Dave '97 Z28 M6's Avatar
You can remove the weight, but I'd take the clutch to a good machine shop and have them spin it up to check for balance to be on the safe side.
Old Nov 1, 2006 | 11:49 PM
ponyackn's Avatar
Thanks Dave. How does that work? I just take the whole clutch and flywheel setup to a shop and ask them to check it? Do they need anything else from me?
Old Nov 2, 2006 | 06:53 AM
Did VRE internally balance your 383?
Old Nov 3, 2006 | 08:44 PM
ponyackn's Avatar
Yes, it was internally balanced. I took it to the shop today and had the weight removed and some additional weight was removed for the neutral balance. Thanks guys. I just hope that it turns out perfect without any vibration, too much money has been spent on the motor at this point.
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
