400 turbo
Old Oct 14, 2006 | 03:07 PM
itzkwik's Avatar
400 turbo
I am going to put a turbo 400 in my lt1 car, my 4l60e hasnt had 4th gear for awhile now so i am used to keeping it under 65 0n the highway , i was wondering if there were any other drawbacks with a 400 that i might be aware of before finally going through with the swap
Old Oct 14, 2006 | 11:04 PM
revtime's Avatar
Re: 400 turbo
The RPM on the hiway with steep gears is the only drawback as far as I am concerned.
I run a Rossler RMVB TH400 and its the best thing I have done to the car. It has now eaten the 3.73 gear 10 bolt I had in there and ate a Ujoint so I will be upgrading the rear at the first of the year.
Throw the TH400 in there and don't look back.
Old Oct 15, 2006 | 12:31 AM
itzkwik's Avatar
Re: 400 turbo
yes, I started with the motor, nitrous cam,2618 srp pistons scat i beams gm 1053 forged crank for flexing, ported heads. probably bout 400 -425hp n/a, but ready for another 300 on the bottle, for all the qoutes i have had on building the most extreme 4l60 minus convertor, I can build a 1000 plus hp th 400 with a neil chance convertor and pulling those trannies buy yourself and without a lift sucks i only want to do it one more time, then i'll start from the yoke back
Old Oct 15, 2006 | 05:37 PM
rskrause's Avatar
Moderator
Re: 400 turbo
Carl Rossler knows these things inside and out.
http://www.rosslertrans.com/
PS: I hated the car without OD, but it was awesome at the track.
Rich
G-BODYT56
Jan 14, 2022 11:14 PM
Kawi
Sep 28, 2015 09:01 AM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
