305TPI aluminum L98 heads
Old Dec 10, 2005 | 12:01 AM
hurstricky's Avatar
Hello, I'm wondering if any one knows of what power gains if I put aluminum L98 heads (2.20 1.60 their 53cc chamber to raise the compresion to 10:1 on the L98)on a 305 TPI. I have a 1991 trans am 305 TPI 5 speed . I got super chip,k&n,dual cat to 3 inch pipe to a 3 inch in and dual 3 inch out flowmaster plus some other goodies.
Old Dec 10, 2005 | 12:11 AM
90rocz's Avatar
Re: 305TPI aluminum L98 heads
Not as much as you'd like. The small bore of the 305 will shroud the big valves, giving only minimal gains. I thought they were 58cc, which is what a stock 305 has.
I'd get some undercut swirl-polished 1.94/1.5's and a proper "3-Angle" valve job, a bowl-port job, and a cam that'll squeeze the most air you can through the valves.
Old Dec 10, 2005 | 12:21 AM
hurstricky's Avatar
I didn't think it would I'll just put the nos on the trans am,and put the heads on 89 IROCZ which has the L98.
Old Dec 10, 2005 | 07:08 AM
91-Z28-L98's Avatar
Thats what I would do.
Old Dec 10, 2005 | 06:39 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Do a search for "corvette heads" or "aluminum heads" on this forum. I have those heads and have posted numerous times about the problems you will run into with them.
First, they're 58cc's, same as your 305 heads. And their valves are 1.94/1.50, same as a stock 350.
Old Dec 10, 2005 | 09:29 PM
95_MuLLeT_LT1's Avatar
I dont think a 2.02 valve will fit on a 305 anyway. Has a little valve to bore issue.
*Emilia*
May 13, 2015 09:05 AM
cmyname1
Feb 19, 2015 08:38 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
