ECM Code 36
ECM Code 36
Code 36 = MAF burn-off circuit
Probable cause:
Code 36 can be set due to high resistance in the burn-off relay contacts or connections, the failure of the ECM to properly ground the circuit, or a poor connection at any of the relays, MAF sensor, and ECM.
Questions:
OK, where is the burn-off relay and what should the resistance be?
Why would the ECM fail to properly ground the circuit?
Any other suggestions would be greatly appreciated. I need to get this thing smoged soon, to complete the transfer of ownership.
Thanks in advance
Probable cause:
Questions:
Thanks in advance
Re: ECM Code 36
This has been covered many times (you should do a search),but here goes. First 9 out of 10 times it is either a loose(poor connection or a faulty relay. Do a wiggle test at all connections especially the main box at the firewall then clear the codes and see if that helps(usually does for a while). Pull and clean any and all connections(yes even the wheather packs)and use some Electrical Anti Corrosion Paste. The relay is usually one of the relays on the firewall by the mastercylinder. I would post a pic,but don't have a link. Pm me you e-mail and I can send you a pic.
Re: ECM Code 36
Thanks for the response I sent you PM.
Re: ECM Code 36
Originally Posted by Kwiksilverz28
Don't bother testing the relay. Just replace it. And check all the connections. Should fix it.
Kwiksilver do you know where this burn-off relay is located on an 89 IROC.
Re: ECM Code 36
Did you get the photo? That shows the relay. Relays are cheap about $15 and are interghangeable with the others. So you can swap them around and if you get a differant code that is the bad one,just change it out with a new one.
Re: ECM Code 36
Sent the pic last night to the addy you gave me. Autozone should have the relays,but the dumba$$ probably doesn't know what he is looking for. Try CarQuest or NAPA,or even PEPboys,Kragens. The GM #is14089936,Car Quest # isRY-109,and Kragens#is Sorensen#MR-44.
