Injector Connector ?
Old Dec 11, 2005 | 09:41 PM
jbrumme's Avatar
This is probably a stupid question, but does it matter what connector goes to which injector on a 91' TPI? I'm trying to trouble shoot a misfire problem and when I removed my intake, stupid me didn't mark the injector wires....
Thanks!
Old Dec 11, 2005 | 11:27 PM
camaroz28racer2's Avatar
Re: Injector Connector ?
No it does not matter on your TPI engine.
Old Dec 12, 2005 | 07:40 AM
91-Z28-L98's Avatar
Just as long as they are on the correct side it doesn't matter, but that shouldn't be hard to figure out. If you suspect a misfire due to an injector not firing, you can test the resistance of each injector. I believe they should be around 17-18 ohms. Basically, if any are significantly off, there is a problem and you should probably get new injectors.
Old Dec 12, 2005 | 07:42 AM
jbrumme's Avatar
Thank you for your replies....I know I have the connectors on the correct side so I will check the resistance on the injectors this afternoon....Thanks again!
Old Dec 15, 2005 | 08:58 AM
jbrumme's Avatar
UPDATE: I checked the the resistance of all the injectors and they all checked around the same 18-19ohms. I found the plugs were all gapped to .035, so I regapped the plugs to .045. Also I found that my fuel pressure was a wopping 70psi!!! Ouch! So I turned that down to 50psi @ idle and 45psi @ 2000rpm. Problem solved! No more misfire! Thanks again for everyones help!
Old Dec 15, 2005 | 06:10 PM
91-Z28-L98's Avatar
That'll do it.
realistyc
Jul 28, 2015 07:32 PM
Anon
Jul 23, 2015 12:18 PM
gelbza
Jul 12, 2015 08:10 AM
mrwz28
Jul 8, 2015 09:11 PM
