Cams?
Old Jan 8, 2006 | 06:35 PM
scott5's Avatar
Cams?
I need to know what is the biggest cam i can put in my motor.
Old Jan 8, 2006 | 08:14 PM
cc89formula's Avatar
Re: Cams?
then you might want to tell us something about your setup
Old Jan 8, 2006 | 10:11 PM
85_305's Avatar
Re: Cams?
Old Jan 9, 2006 | 07:52 AM
scott5's Avatar
Re: Cams?
this is for a friend. He has a 92 Z28 which has the L98 350 tpi. What else do you need to know about it?
Old Jan 9, 2006 | 08:02 AM
teke184's Avatar
Re: Cams?
well there is no definative answer for your question.
the main problem you'll have is that the TPI system on that engine is very limited in performance above 5000rpms. and most big cams will peak much higher than that.
does he have all the boltons to support the cam? how bout heads? headers? torque converter?
give us a hp goal and we can probably give you a MUCH better idea on what to get.
Old Jan 10, 2006 | 05:12 AM
iansane's Avatar
Re: Cams?
So it's completly stock?
Side note, I love when people reiterate L98 350 TPI. Yeah. Once you said L98, everyone knows it's a 350 with TPI on top. There's no reason to keep talking. Although if you were to continue, you forgot B2L.
Old Jan 10, 2006 | 07:37 AM
scott5's Avatar
Re: Cams?
IT has exhaust, intake, headers and i dotn know what else, like i said this was for a friend.
Old Jan 10, 2006 | 08:34 AM
teke184's Avatar
Re: Cams?
get a nice fat RV torque cam
take advantage of the torque building ability of the TPI, as well as the low rpm range the TPI is limited by.
a cam that peaks at 5000 would be great since the TPI falls on it's face right around there.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
