fire from coil to cap, but not spark plugs
Old Dec 19, 2005 | 06:00 PM
theredone's Avatar
i had a situation where, it was hard to start my car. i had no spark from cap to plugs (new cap rotor, checked coil) I would have to rotate the distributor milimeters at a time then i finally fired up. is that normal?
1988 camaro iroc 350 tpi stock 124,000 miles
Old Dec 19, 2005 | 07:11 PM
91-Z28-L98's Avatar
Re: fire from coil to cap, but not spark plugs
Definately not normal. Are you sure your plugs were getting no spark? It sounds to me like your timing was way off and you were correcting it to get it to start. This problem could be caused by your distributor hold down clamp being loose (It would have to be for you to be able to turn it). With the clamp loose, the base timing would be free to change itself pretty much randomly.
On the other hand, in order for timing to cause a severe hard start, it has to be WAY off. I once had my timing set to 4 degrees after top dead center and the car still started fine, but had no power and crap idle.
Old Dec 19, 2005 | 08:18 PM
89_Irocz's Avatar
I see your car has 124K on it, Have you ever changed the timming chain and gears?
Old Dec 19, 2005 | 08:32 PM
theredone's Avatar
new motor and wires
Old Dec 19, 2005 | 09:45 PM
Pneumatic_Tire's Avatar
Rotor button in the cap burnt up? Take the cap off and check it out.
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
