91 Z28 355 1LE---> BAD brakes :(
Old Jan 16, 2006 | 11:01 PM
Bristol's Avatar
Anyone running a electric vacuum pump? Im having braking issues and am thinking its a vacuum issue since with my cam and intake am only pulling 13"-14" warm in park and 10"-11" in gear. Braking just plane and simple sucks. Pedal goes hard after 2-3 pumps and car feels like its coasting to a stop where as before I could lock them up. Already have a vacuum can and it made absolutely no change. 1 way valves are all new and functioning. No vacuum leaks and the car runs very well considering it is running a 100% stock tune. Booster is holding pressure, good fluid flow at bleed screws, no air pockets, upgraded Earls lines, good pad and rotor life. Im trying to borrow an electric pump just to test this theory. Anyonw with any experience or suggestions on how to fix/diag. this issue? Thanks
Kris
Old Jan 17, 2006 | 02:17 PM
Z28SORR's Avatar
Re: 91 Z28 355 1LE---> BAD brakes :(
You could always get rid of the power brakes.
Old Jan 18, 2006 | 02:53 PM
85_305's Avatar
good story
Old Jan 19, 2006 | 05:03 PM
1991l98g92's Avatar
Another possibility, don't know how feesable, maybe changing to a hydro-boost. Like the 7.4L trucks running off power steering pressure...???
LeftoverChinese
Jan 14, 2024 03:03 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
