Is there anything i shoule clean or check/tighten under dist cap?
Old Nov 29, 2005 | 03:42 PM
BLACK Z !'s Avatar
I am replaceing the iginition control module with accell one and i ws wondering while I am in there is there anything else I should check? Can I spray it with a cleaner? Can I put dielectric grease on all of the plug connections? thanks
Old Nov 29, 2005 | 11:25 PM
90rocz's Avatar
Re: Is there anything i shoule clean or check/tighten under dist cap?
Make sure to put plenty of "WHITE" "heat-sink" grease under the module, or it will fail again...dielectric grease won't do it. Check for bare spots on the wiring in there too.
Old Nov 30, 2005 | 10:46 AM
BLACK Z !'s Avatar
Where do I get this grease from?
Old Dec 4, 2005 | 10:39 PM
coolram62's Avatar
Most auto parts stores will carry the heat sink grease(I don't recall the proper name for it)for module installtion.Dielectric grease is good for spark plug boots - both ends,inside wire connectors and on lamp contact bases.While you have the dist open,before you install the module,you could use a good quality electrical contact cleaner - most have a drying agent - to clean the housing of residue from the contact arc inside the cap.Low pressure compressed air,even the can type you use on computors,is good to clean it ou.
Old Dec 5, 2005 | 07:08 AM
pigsticker's Avatar
I've got a tube that I bought from Radio Shack.
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
Fastbird93
Jul 11, 2015 04:37 PM
CARiD
Jul 7, 2015 08:19 AM
