90 5.0 Header Help! Pass side hit A/C Box
Old Feb 9, 2006 | 06:23 PM
GWAR4NEWWORLDORDER's Avatar
Unhappy 90 5.0 Header Help! Pass side hit A/C Box
Please help. My A/c box is really pissn me off. I recently purchased new shorty header 3” y pipe CAT, and CAT back. I stuck on the passenger side with interference issues. I’m forced to install the header from the top, but it’s hitting the box that surrounds the A/C @ the firewall. What do I need to remove to complete this installation?
Lost In Pittsburgh
Old Feb 9, 2006 | 07:20 PM
ws6transam's Avatar
Re: 90 5.0 Header Help! Pass side hit A/C Box
Have You checked your motor mounts recently?
I overlooked mine, which are now 22 years old. WHen I tried to install my heeaders last week, I discovered interference issues on the Hooker headers. An investigation showed that the motor mounts had sagged 1/2 inch and that was enough to cause the interference.
However, it that ain't it, try removing the starter and all the spark plugs. Pull the passenger side motor mount bolt, raise the car up as high as you can on jack stands, temporarily remove the bolts to the transmission mount, then place a jack under the oilpan and give it a shove upwards. The engine should move up and away from the passenger side, enabling you to slip the header in from the bottom.
Old Feb 9, 2006 | 08:09 PM
I will try it thanks!
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
