How to pick an LB9 cam?
Old Feb 11, 2006 | 02:04 PM
calcm27's Avatar
Question How to pick an LB9 cam?
I want to know how lift effects HP and Torque
Compare single pattern vs. dual pattern. Low lift vs. high lift. and a mix of both, low intake/high exhaust, mabey using 1.5rockers on one side and 1.6 on the other. Use 204-220 for duration.
Ready? Explain!
Old Feb 11, 2006 | 02:09 PM
V8Rumble's Avatar
Talking Re: How to pick an LB9 cam?
For questions like that, I've heard that search engines are occasionally helpful...
Old Feb 11, 2006 | 02:37 PM
calcm27's Avatar
occasionally, but not in this case, I have not found any threads SPECIFICALY comparing cam lift on a TPI 305
Old Feb 11, 2006 | 11:40 PM
89Vert's Avatar
do you have a MAP(90-92) or MAf car(85-89)
MAP cars do not react well at all to cams much different then stock,
because there timing/fuel is based on vacuum and not airflow like MAF
cams tend to effect vacuum alot which really throws the MAP ECM for a loop
MAF cars are better to modify then MAP cars simply cause the ECM uses air flow to deterim fuel and timing, with a bigger cam the ecm reconizes that more air is flowing into the motor,
MAP cars need custom tuned chips to run a cam,
if you go real big MAP or MAF you'll need a custom chip
Old Feb 12, 2006 | 09:02 AM
calcm27's Avatar
I have a MAP LB9. If I decide to do a cam swap, Ill have the car dyno tuned and a custom chip.
So, anyone got input on my queston about lift?
Old Feb 12, 2006 | 02:28 PM
89Vert's Avatar
there is alot of thing you have to consider when buying a cam,
main is what intake,
stock TPI is only good to about 5000rpm for a power range,
putting a 2500-6500 rpm cam is a waste,
when building a performance motor you have to take your whole system in to consideration
look for a cam that makes power under 5500rpm,
not really that knowledgable when it come to all the dual patern single patern and duration
I have a program called desktop dyno its fairly accurate if you put exact cam and head specs in
Old Feb 12, 2006 | 04:46 PM
calcm27's Avatar
I know TPI is no good above 5000rpm. I had a desktop dyno CD, but lost it. My friend will burn me another one
Old Feb 14, 2006 | 01:45 PM
iansane's Avatar
Are you planning on keeping the 305 or something? Save money and pick up a used lt1 cam for $10 and a gasket set for $35 and be done. Put the other money towards a more effecient engine.
Old Feb 15, 2006 | 07:24 PM
calcm27's Avatar
Dont need a new engine when all I wanna do is spice up my daily driver a bit. Especially when theres only 41K miles on it. If I wanna go fast I hop into my 11sec Camaro
Old Feb 16, 2006 | 12:03 AM
iansane's Avatar
Your definition of spice is much milder than mine then.
drptop70ss
Mar 26, 2015 01:50 AM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
skittlez87
Dec 29, 2014 03:23 PM
siguy
Nov 27, 2014 10:07 AM
