Engine Swap Help
Old Dec 6, 2005 | 09:23 AM
shuf's Avatar
Engine Swap Help
Hello,
I have a 1989 Firebird Formula w/ the original 305 TBI motor in it. I built up a '79 350 small block before I purchased the car, and I wanted to look into putting this motor in. I was looking at both engines, and it seems that the front components (alternator, water pump, pwr steering pump, etc) of the 305 won't just bolt on to the 350. Is this correct? Are there any adaptor kits available?
Thanks in advanced,
Steve
Old Dec 6, 2005 | 11:01 AM
RedIrocZ-28's Avatar
Re: Engine Swap Help
There should be no reason that the brackets will not interchangeably swap between engines. 79 was a GEN I Small block, and every year up to 1992 also used a GEN I small block Chevy.
Old Dec 6, 2005 | 11:07 AM
respectirocz's Avatar
you can easilyswap over any and all brackets, the only thing i would be concerned about is the water pump, i'm not too familiar but some gen i sbc's have a longer water pump
Old Dec 6, 2005 | 01:53 PM
96m6lt1's Avatar
the only real problem is if the dipstick is on the drivers side you will have a hard time with the ex.manifold and dipstick combo,use headers.....as far as the waterpump they are all long style with the exception of the v8 monza it is a short style,'88 started the rev.rotation so just use the pump for the car and serpentine acc.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
