speedo/inst. lights
Old Nov 24, 2005 | 09:50 PM
protr's Avatar
speedo/inst. lights
I know this is a lame question, but how do I replace the instrument panel lights...I tried access by removing the dash pad, but had no luck....any suggestions would be appreciated...by the way, this is for a '91 RS.
Old Nov 27, 2005 | 08:51 PM
FirebatLT1's Avatar
Re: speedo/inst. lights
i dont know about thirdgen camaros. I've taken apart thirdgen firebird and forthgen camaro dashes. Just start taking off bolts and parts in front and and th e bottom of the dash until you get it out. Then twist off the bulbs and replace them. If ALL the bulbs are out, check your fuses and then check your wires.
Old Nov 28, 2005 | 06:13 PM
gixxer92's Avatar
Take the screws out of the face plate, remove the face plate Drop the two nuts off the steering column <makes it easier>, take the 5-6 screws out of the white plastic guage cluster and it should come out. I think <long time ago>, you have to disconnect the speedo cable and the wiring plug to get the cluster out. Once out, the bulbs are on the back side. I think they are a 194LL are the replacements that you want if your using the Auto Store bulbs. 90 degree twist CCW, releases them from the contact sheet on the back side.
Old Nov 28, 2005 | 10:15 PM
gixxer92's Avatar
Oh yeah just remembered, there is a black plate behind the front cluster bezel that has 4-5 screws that have to come out before you get to the main guage cluster.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
