how close?
Old Jan 29, 2006 | 06:55 PM
roosterjuicer's Avatar
how close?
a buddy of mine is thinking about getting a 89 mustang gt 5-sp convertible. i have a 1992 z28 305 5-sp. both cars would be bone stock.
i know that a 5.0 is usually a little faster than the 305's cause they are lighter, but i figure a convertible will be heavier and my car has 77k miles where as his would be more around 140 or so.
can i win? if not, how close would it be considering equal driver skill.
Old Jan 29, 2006 | 07:04 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: how close?
Do you have the dual cat option with 3.42 gears or the single cat with 3.08 gears?
Old Jan 29, 2006 | 07:13 PM
Re: how close?
i have the dual cat, but i dont know my gear ratio.
Old Jan 29, 2006 | 07:25 PM
thirdgenrallysport's Avatar
Re: how close?
i think it may be a close race. i thought the ford 5.0 put out more power than the LB9 305 tpi.
Old Jan 29, 2006 | 07:33 PM
Re: how close?
there are varying numbers but the 5.0 is around 225 and ive seen numbers ranging from 220-230 on the 305.
Old Jan 29, 2006 | 07:46 PM
Re: how close?
well i know they kicked my ***, when i had the tbi 305/ boat anchor in my car. now i dont care cuz they are all slow, now let me know the results of this comparison. ill put my money on the camaro though
Old Feb 3, 2006 | 12:39 AM
Kevin91Z's Avatar
Re: how close?
Dual-cat cars should have 3.42 gears by default. Look at your RPO codes in the locking box in the trunk and see if you find G92 (perforance rear axle), N10 (dual-cats) and GU6 (3.42 gears).
Old Feb 3, 2006 | 06:49 PM
Re: how close?
sweet...so what all does that translate to for me? are 3.42 gears super sweet? whats the difference between the g92 axle and a normal one? how much power do the dual cats give me over a normal 305 z28?
Old Feb 4, 2006 | 05:59 PM
Kevin91Z's Avatar
Re: how close?
Performance axle just means the gear ratio, 3.42 is better than 3.08. Also the 3.42 rear ends will have disc brakes, the 3.08 has drums.
The dual-cat exhaust is rated at anywhere from 10 to 25 more horsepower, depending on who you ask.
Old Feb 4, 2006 | 06:55 PM
doug791's Avatar
Re: how close?
really i could run dead even in my dads ghetto 92 saab 9000 and those cars, looked like a grand mothers car, well it was, little turbo 4 cylinder.
Either way youre both going to be getting smoked by slow *** cars on the street.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
tdigger9899
Sep 7, 2015 10:56 AM
