305 Tpi
Old Dec 12, 2005 | 06:55 PM
cruiser's Avatar
305 Tpi
I have a 91Z28 with TPI...it`s a 305 and my first question is....should i drop a 350 in it? i keep hearing that a 350 LS1 is the motor to go to if you want real speed....i drive on the highway daily so i want something that cranks up and runs STRONG if i need a real passing gear.....also, should i change my existing tranny?...thanks for any response...remember, this is my daily driver but it is extremely clean....i`m not building a track type of car....i`m staying with an automatic
Old Dec 12, 2005 | 07:21 PM
89_Irocz's Avatar
Re: 305 Tpi
LS1's are nice but alot of work and money. (have to change tranny) You can change it to a 350 TPI (L98) in about a day, and for about $1,500
Old Dec 12, 2005 | 07:38 PM
cruiser's Avatar
Re: 305 Tpi
when i change it to a 350, don`t i have to also change the brain and alot of other sensors etc..? also, lately my speedo and odo work only once in while...is that the sensor or plug on the tranny going bad?...
Old Dec 12, 2005 | 09:00 PM
91-Z28-L98's Avatar
Re: 305 Tpi
The L98 (small block 350 TPI) is a direct swap for your 305. You could realistically swap only the short block plus heads and use your existing intake, exhaust etc. The computer and injectors are slightly different but will still work fine... not optimal without a custom tune, but it will react much like any other mod. You will eventually need to upgrade the injectors and retune the PROM anyway.
Old Dec 12, 2005 | 10:36 PM
89_Irocz's Avatar
Re: 305 Tpi
I took out the 305 TPI (LB9) and put in the Complete 350 TPI (L98) and only had to change the computer box. Wiring was all the same.
Old Dec 13, 2005 | 01:10 AM
cruiser's Avatar
Re: 305 Tpi
man...i really appreciate all the info...thanks.
Old Dec 13, 2005 | 10:28 AM
Zepher's Avatar
Re: 305 Tpi
computers are the same, it is only the memcal (large wide electronic part with teh eprom attached to it) that is different.
Old Dec 15, 2005 | 11:50 AM
Pneumatic_Tire's Avatar
Re: 305 Tpi
You said "teh".
G-BODYT56
Jan 14, 2022 11:14 PM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
