Catalytic Converter
Old Jan 27, 2006 | 08:37 PM
ringo234's Avatar
Catalytic Converter
I was told I need a 3-way converter. Co2 carbon monoxide, and Nitrogen Oxide. Is the Catco a 3-way converter.
Old Jan 28, 2006 | 04:40 PM
thirdgenrallysport's Avatar
Re: Catalytic Converter
first off do you really need a cat? where are you from?
Old Jan 28, 2006 | 05:15 PM
87DJP2001's Avatar
P/N for the Catco Converter you need is CTO-9118 and can be bought from Sumitt Racing for about $127. It will be a direct fit hi-flow replacement and will work with EGR.
Old Jan 28, 2006 | 06:01 PM
ringo234's Avatar
Yes I can't pass smog without it. I'm in So. Cal. (the toughest smog state)
Thanks 87DJP2001
Old Jan 30, 2006 | 04:50 PM
1991l98g92's Avatar
Make sure it's C.A.R.B. approved for your year model and engine size. If it is, put the under hood label on and have all paperwork with you when you go to get it smogged. All aftermarket parts need to be approved for California.
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
