timing an 89 350tpi
Old Feb 11, 2006 | 05:33 PM
70cst10's Avatar
timing an 89 350tpi
What should the timing be for a fatory 350tpi? It came from an 89 firebird formula with a 700r4. Thanks!!!
Old Feb 11, 2006 | 08:24 PM
LesPaulGoth's Avatar
Re: timing an 89 350tpi
They came from the factory with a 6* advance, but you can run 8* and still run 87 octane.
Old Feb 11, 2006 | 11:24 PM
89Vert's Avatar
leave it stock unless you run high octane fuel
TPI has a knock sensor, you won't here the knock, but the ECM will be retarding your timing
I run 94 octane all the time(canada) and have my base timing set to 8*
I'll still see alot of knock retard on a hot day as much as 11* at WOT
with your timing at 8* and running 87 its possible your sending your car in to low octane mode,
low octane mode is a less aggressive spark table put into effect when knock is sensed over an extended period of time,
which is actually worse,
really to stay out of low octane mode you should run 91 octane with 6* base timing
the real way to adjust your timing is with a custom prom
get a datalogger and check your knock retard,
main problem with adjusting your base timing is your effecting the whole timing curve,
you should adjust timing through datalogging and custom tuning of a chip,
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
