TBI->4bbl
Old Nov 23, 2005 | 03:15 PM
Unix's Avatar
Lightbulb TBI->4bbl
Hi , recently i swapped my V6 to V8 TBI, and I'm having a real ****ing hard time getting all the codes cleared (the wiring harness is a total mess)... I'm out of patience, and i wanna know what i need to change from TBI to 4bbl carb.
I know i need a new distributor, intake, and a carb. I'm not to sure about the distributor, what kind do i need so it works with a simple carb?
here are the possible options on summit:
# Mechanical,
# Vacuum and mechanical,
# Vacuum,
# Electronic,
# Electronic and vacuum,
which one is it?
thx for the info, i'm really pissed my car is out of order for the past 2 months thx to fuel injection
Old Nov 23, 2005 | 07:24 PM
blown3rdgen's Avatar
Re: TBI->4bbl
My old set-up:
I used accel dist #9107 (I think) w/ vacuum adv. Its cheap, easy to get, comes with cap/rotor/spring kit.
Fuel pressure regulator (mallory #4309)
For intake- rpm air-gap
For carb- 600cfm (assuming 305)
You should be able to find all info with "search" button
Old Nov 23, 2005 | 07:58 PM
85_305's Avatar
Re: TBI->4bbl
^That about sums it up. As long as you dont go computer-controlled you wont have a problem. No wires is teh
Eddie 600 Performer, Accel distributor (vacuum advance), and either a RPM Airgap intake (for topend power) or a Performer intake (for torque).
Old Nov 24, 2005 | 05:18 AM
Unix's Avatar
Re: TBI->4bbl
Ok thx for all the info, it's all i needed
I'm gonna go for TQ about the carb i'll probably be getting a 500cfm, even if it starves the engine in the top end, i really care about gas mileage
Old Nov 24, 2005 | 05:32 AM
Unix's Avatar
Re: TBI->4bbl
i'd say this is even a better deal on the distributor, it already has a mounted coil.
http://store.summitracing.com/partde...0&autoview=sku
what do u think ?
Old Nov 24, 2005 | 07:26 AM
Dave89IROC's Avatar
Re: TBI->4bbl
what do u think ?
thats fine
Old Nov 24, 2005 | 01:30 PM
85_305's Avatar
Re: TBI->4bbl
A 500cfm is a VERY bad choice. That flows less than a stock Q-Jet unit. Your not only going to get sh*tty gas mileage, your gonna have ZERO performance unless you go with a 600cfm+..
Old Nov 26, 2005 | 12:09 PM
Unix's Avatar
Re: TBI->4bbl
everybody seems to be saying the same thing, so I'll go with the 600cfm
thx for the info by the way
Old Nov 26, 2005 | 01:06 PM
85_305's Avatar
Re: TBI->4bbl
^No problem, anything to help a fellow Third Gen'er
z28draco
Mar 10, 2005 10:59 PM
patRIOTik
12
Oct 6, 2004 04:22 PM
zrs
Parts Wanted
Feb 28, 2004 05:13 PM
77MadMax
N2O Tech
Jan 3, 2003 10:23 AM
