New Member IROCU2
Old Nov 24, 2005 | 10:27 AM
IROCU2's Avatar
New Member IROCU2
Just wanted to say hello to everyone. I am a new member here on the board. I own a 1987 IROC 5.7 no T-Tops. need help in finding out how do you replace the headlight switch For some reason I can not figure it out. Can someone help me out with this? Thanks
Old Nov 24, 2005 | 10:45 AM
Dave89IROC's Avatar
Re: New Member IROCU2
its a pain in the butt
IIRC, you need to pull trim(can't remember what) to access it, push a small metal button to release the ****, turn the nut under the **** to get the switch loose, then wiggle it out, then unplug the wires
Old Nov 24, 2005 | 10:55 AM
IROCU2's Avatar
What is IIRC? I tried to take the dash off to get to it but no luck. Are you talking about the trim under the dash?
Old Nov 24, 2005 | 11:46 AM
LaxStreetRacer's Avatar
Hey IROCU2 welcome to the board, underneath the dash there is a big plastic trim panel, take that off. Look up from the underneath of where the switch is there is a spot on the bottom of the switch you need to stick a screwdriver in to release the *** (pull the fuse first). Once you get the *** out you are on your own but you should be able to figure it out from there.
Also, IIRC is shorthand for "If I remember correctly". If you can't get it figured out post it in the Electronics section on www.thirdgen.org and I have no doubt someone there could give you better instructions. It's a purely tech site and it's only for the third gen F-bodys.
Old Nov 26, 2005 | 12:55 AM
AutoRoc's Avatar
Welcome! and Goodluck. hehe..May you have half the headaches that we have alll had with our IROC-Zs...
Old Nov 26, 2005 | 08:13 AM
Tom87IROC's Avatar
Welcome IROCU2! Nice to see another 87 IROC 5.7L on the block. Mine now has 73,000 miles and it's starting to need a lot more attention. I still have most of my original paint and the spoiler on my trunk lid is really fading. I have not had a problem with the headlight switch yet, but that gives me something to watch out for.
Good Luck with your IROC!
Old Nov 26, 2005 | 09:36 PM
respectirocz's Avatar
another 87 iroc over here, only i have the lg4 motor, with a 5speed and t-tops
lt1 soon to come
anyway
on the bezel that holds the headlioght switch {and foglights =)}
it loks like there are 4 screws
torxs head screws
only 2 areal 2 are fake
remove the two real ones, dont rememebr which
underneath the switch itself is a button that releases the ****
if u bought the new switch already (i recommend it) you will see how it works
then remove the harness and whatever screws hold it in place
reassemble and voila
have fun
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
