Stock cam specs?
Old Jan 18, 2006 | 09:13 PM
elementaltoad's Avatar
Stock cam specs?
Does anyone know the stock cam specifications for a 1988 formula 350, TPI. I want to eventually go with cams and better heads. I want to have that musclecar idle to it that just shakes the car, and still remain within the 5500 RPM limit. Also I'm eventually going to a blower, magnacharger twin screw, so I'd like to keep as close to stock compression as possible.
Old Jan 19, 2006 | 12:09 AM
cc89formula's Avatar
Re: Stock cam specs?
stock cam is like 207/213 and .413/.417 lift numbers may be wrong but theyre close
Old Jan 19, 2006 | 07:23 AM
teke184's Avatar
"eventually go with cams and better heads"
pssst...
there is only one cam in it
Old Jan 19, 2006 | 08:44 AM
87DJP2001's Avatar
1988 TPI 350 stock cam spec was:
Lift 415/430
Dur 207/213
Sep 117
Old Jan 19, 2006 | 12:59 PM
lol i know there is only one cam...im not that oblivious :-P just trying to figure out my best combo before i go tearing things apart. I want to get teh most low compression hp/tq out of the car before is supercharge it.
Old Jan 22, 2006 | 10:14 PM
Ok so i dont want to crush my fuel mileage, and i need drivability. But i would really like the idle to have a bit more lope to it, to give that muscle car kinda feel and torque. does this came look to harsh for fuel mileage? Im not really sure what kinda of duration numbers to look for.
http://cranecams.com/?show=browsePar...tType=camshaft
That one seems to be mild enough, and will fit the original RPM range fairly well. I also intend to stick with the TPI setup, and put on a high flow base and runners when i do the cam. The the heads will be ported and polished when i have the money. So all in all my engine wouldnt need much more of an aggressive cam with the given RPM range would it?
Old Jan 22, 2006 | 10:57 PM
faded93bird's Avatar
hotcam kit, lopes, makes good power nuff said
Old Jan 23, 2006 | 01:36 PM
Will i have to mod anything? mine is just a stock L98, so i cant use something to agressive otherwise i kill low end power, mileage and then end up with a power band on a TPI i cant reach.
Old Jan 24, 2006 | 07:26 PM
Ok so it looks like the L98 heads will work with the LT4 hot cam lift and all.
I think my setup will be:
Ported L98 iron heads
LT4 Hot Cam Kit
Edlebrock Hi-Flo TPI Kit
Edlebrock Ti-Tech Headers
Edlebrock Exhaust
Custom Tune
Built TH700R4
Anyone have a fair guess as to what it might it might put on the dyno?
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
blac94Z
Feb 18, 2015 11:36 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
