evil gremlin?
evil gremlin?
Hi !
I have a problem with my Camaro 5.0 TBI... the SES light is on and it reads code 43 - Low voltage at electronic spark timing circuit . What could be the problem
The ignition module is ok, the knock sensor as well. The engine seems to be running ok. Does anybody have any suggestions on what it could be ?
thx for any info !
The ignition module is ok, the knock sensor as well. The engine seems to be running ok. Does anybody have any suggestions on what it could be ?thx for any info !
Re: evil gremlin?
Originally Posted by bmillington
Is that the only code? I think thats the one you always get when the engine is not running (because the distbuter is not turning).
Re: evil gremlin?
had the same problem with my car...change out your knock sensor and it should go away. If you read in your hans manuel or w/e, it says if they ecm stops recieving a signal from the knock sensor, itll throw the code.
Re: evil gremlin?
Re: evil gremlin?
thats your esc module
you can see it here...www.tpiparts.net
go to catalog then the ignition section..its in there (just in case you may need a new 1 and want gm quality parts)
o and sorry about the knock sensor thing, i didnt realize you had checked it already
Re: evil gremlin?
doc212121
May 7, 2004 07:15 PM
Frank99'z-28
Jul 16, 2002 05:58 AM
Frank99'z-28
Advanced Tech
