what the hel did i do, what is normal
Old Mar 23, 2004 | 05:24 PM
lordmetalz28's Avatar
so i ****ed with my shift cable on my throttle body on my tpi motor. i saw an article on thirdgen.com that said push the d shapped button in and pull the cable back tight. i did this. then i manually pulled the throttle linkage to WOT like it said. then i drove and i couldnt shift out of first gear. so then theres this little plastic piece i adjusted up front on the throttle linkage . adjusted it till i have smooth shifts at decient rpm . what is normal on this thing like factory specs. my shifts are just kinda dropping into gera now. when i first did it they where slamming into gear. where do i want this adjustment set at. did i **** something up?
Old Mar 23, 2004 | 05:37 PM
when a tranny slams into gear what does that mean. normal or something wrong
Old Mar 23, 2004 | 05:41 PM
Rice Killer87's Avatar
if its slamming,it could be u just jacking w/ the cable.
as far as shifts go,it should shift at a decent RPM...prob. between 2,500 or so while driving normal. it shouldnt hold any gear before it shifts. if it holds a gear and then shifts,it will probably be hard. i would just go look at the instructions again,go back and do it again and see if it helps...maybe u read somethin wrong.
hope that helps
Old Mar 23, 2004 | 05:44 PM
your riight i think i only pulled it open a quater throttle cause i was nervous i was gonna snap it. ill try again tommrow
Old Mar 23, 2004 | 05:55 PM
na it wont snap man,ur cars got a Bow Tie on the front doesnt it?
Old Mar 23, 2004 | 06:00 PM
very true, but tell that to the bottom tps sensor bolt(currently bieng held on with one overtightened bolt up top)
Old Mar 23, 2004 | 06:19 PM
kevin 2.8's Avatar
the bottom tps bolt broke on mine too.
Old Mar 23, 2004 | 06:37 PM
fu$$$$$$$$$$$$$$k. so i went outside followed the directions to a tee. didnt work. still held the shift and wouldnt go into second. so now i adjusted it to at normal driving will switch gears smoothly at 2000rpm at mid throttle, about 3500 from first to second 4000 from second to third then it seems like it shifts into fourth drops 500 rpm then holds a bit then drops another 500rpm into 4th something is ****ed upppppppppp. im just gonna bring it to a mechanix before i get so mad i fu$kin sell it.
Old Mar 23, 2004 | 06:42 PM
another question the black skin i guess which goes over the cable is just a cover the cable is silver. the black part when i pulled ti twoards the firewall kinda slid back without the silver cable sliding
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
