O2 sensor placement question...
Old Mar 30, 2004 | 08:38 PM
dj haf's Avatar
i have a set of hedman long tubes for my iroc that im having installed while the engine is out. my mechanic told me the headers were too pretty to drill a hole in, and that he'd rather wait to put the o2 sensor in after i get myself a custom y-pipe and he'd put the o2 sensor in the y-pipe instead of the headers. do you think that's wise? or should i just have him put the o2 sensor right at the end of the header? thanks guys
Old Mar 30, 2004 | 08:45 PM
PyRo9862's Avatar
Ive heard of doing it in the Y pipe, on my headers putting the o2 sensor in the y pipe would only be brining it back another couple of inchs. You know you need a heated o2 sensor (whatever that is) though.
Old Mar 30, 2004 | 09:03 PM
klumb15's Avatar
well you don't want to put it too far back, because the o2 sensor doesn't kick in untill 600 degrees....and the only way it gets that high is by placing it close to the headers...If it were me, i would put it in the header, y pipe i think will be too far back..IMO
Old Mar 30, 2004 | 09:50 PM
Dave89IROC's Avatar
he just needs to use a 3 wire heated o2 sensor
if you use a heated sensor, the pipe right after the header will be fine
that is where the o2 is going when I do my LT1 swap
Old Mar 31, 2004 | 12:42 AM
dj haf's Avatar
yeah i have a heated o2 sensor... i guess it really doesn't matter then. thanks guys
Old Mar 31, 2004 | 10:51 AM
aklim's Avatar
I would say just drill the damned thing. O2 sensors in the stock location with low backpressure systems have been known in cold weather to cycle in and out of the correct temp. Besides I really don't like it that close to the ground.
Old Mar 31, 2004 | 03:44 PM
dj haf's Avatar
hehe, it never gets cold in miami. maybe in winter it'll get down to the 50's at night, but that's about it.
98-LS1Z28
Sep 8, 2015 03:12 PM
MDZ28
Sep 7, 2015 09:16 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
