Transmission Flush & Rearend Build
Ok guys, I'm draining my transmission fluid out and replacing it with redline...how many quarts of redline should I buy?
Rebuilding my 10 bolt... I got the ratech complete gear install kit, motive pro-street 4:10 gears, TA stud cover girdle and stud kit... What else do I need to make this rearend beefy? I don't want to spend more then a hundred dollars or so beyond what I've already put into it, unless its something of massive importance...
If you can, please include links to where I can order the things you recommend, or at least a general pricetag, etc.
Thanks again guys.
Have a fun summer.
Thanks again guys.
Have a fun summer.
1. That's not a trans flush. That's a drain and fill. You're only removing whats in the pan, roughly 4-5 quarts. You should do an entire flush. There are some DIY methods out there (as usual a search yields good results), but I'd recommend taking it to a shop or dealer to have it done. Expensive, but well worth it!
2. The 4.10s will hurt the rears durability. The gears can only be so large, so increasing tooth count (higher numerical gears) means the teeth are smaller and weaker. Welding the tubes to the housing is a proven method of strengthening the rear, and cost effective too!
Where can I get the solid pinion spacer and how much will it cost me?
I know the 4:10's will hurt my rearend reliability... I'm assuming its even worse that its a 2 series carrier, not 3... but I'm just trying to make it work. I'm not going to be TOO hard on the car with the gears in there...so I'm hoping it'll last at least fairly long.
Anyone want to take a guess as to how long it'll last? Stage II shift kit, about 300 horsepower motor after the cam... I only drive it (cruising) friday and saturday nights. Mostly just idling along at 35 MPH...the occasional hard launch up to 70 or so.
By "weld the tubes to the housing" do you mean the axle tubes??
Thanks for the help guys.
yeah I know... heh, you already yelled at me for the 4:10's aklim. :P
In my figuring though, when I blow the 700R up, I'll replace it with the T56...and then the 4:10s'll be JUST right.
Other than welding the tubes, you've got it covered. Most vendors will have a solid pinion spacer. I think that's the same as a solid crush sleeve. Check www.ThunderRacing.com
NOTE: Love the comment "I'm not going to be TOO hard on the car with the gears in there" Right Brant, keep thinking that
Haha good luck man!
I searched through TR and couldn't find that solid pinion spacer you guys were talking about... And damnit rippin, it took me like ten minutes to realize that was you. :P
And uh, yeah, he's right. Nix that last sentence and replace it with "I plan to beat the **** out of it, how do I make it stronger?" lol
